I recently realised that my car does not have ABS.
Would my stopping distances increase?
Does it make a lot of difference in good conditions (e.g dry, smooth roads)?
Would it make any difference in icy conditions?
In terms of stopping in an emergency situation (i.e. maximum pressure on the brake pedal), what are the other effects of not having ABS?
    ABS is a must have on any car, its of paramount safety , the combo of ABS,EBD and Airbags save tons of lives.
    – Shobin P
    Commented Jun 9, 2015 at 3:00
    My car is 12 years old. It does not have Electronic Brakeforce Distribution, ESC, Traction Control or brake assist as options... It does have lots of airbags though
    – George
    Commented Jun 9, 2015 at 16:22
    All of the above electronics are there to prevent the air bag from deploying :-)
    – Shobin P
    Commented Jun 9, 2015 at 17:08
ABS (should) allow for the best stopping traction you can get (in a perfect world) on the road surface regardless of road conditions.
That said, you see some caveats in the mix there. I'll try to explain.
I say should allow for the best. All ABS systems are not created equal. Some work better than others (though I'm not going to break those out). ABS design should allow for the wheels to break traction with the road surface for only a smallest amount of time (hundredths or tenths of a second). As a tire loses traction, it stops rotating. The wheel speed sensor picks this up and tells the ABS pump to cycle on that wheel which allows the wheel to start spinning again. Then the cycle starts again. The computer is checking all four wheels at the same time (for most ABS systems ... some only have one sensor for the rear brakes, which relies on the spinning of the differential to tell it when it's moving or not. This is not a big deal as over 60% of the braking is done on the front end and the front is where the turning occurs, so traction during stopping is way more important there.) There is a situation on ice, if all four wheels were to stop spinning at the same moment (complete lockup), the ABS system will not react, because all four wheels are rotating at the same rate (ie: not spinning at all). This would make for the car to slide uncontrollably, unless you can get the tires to start rolling again, which means releasing then reapplying the brakes, which means great stopping distance. Ice is a special case, though. The regular recommendation is to not drive on ice, but hopefully that is only common sense.
For the most part, yes, your stopping distance will increase over a similarly equipped vehicle with ABS present. The reason is because the ABS pump can cycle much faster than you can pump the brakes.
ABS does nothing for stopping distance up to the point of where the tire break traction with the road surface. When that happens, the ABS kicks in and does its job, which greatly reduces your stopping distance. When the road surface is good, the ABS has less of a chance to activate, even during hard braking. That is because the grip between your tires and the road surface is much greater. Your tires will usually start to lose grip at the point I'd call emergency braking ... where you really need to stop fast. This is when you can expect the ABS to kick in and this is the point at which you need it the most.
One of the greatest dangers with your wheels locking up, which ABS pretty much solves, is that when the front tires lock up, you lose the ability to steer your vehicle. During emergency stopping, without ABS, your front tires would have the tendency to lock up. When this happens, you can try and steer all you want, but your momentum will carry you in the same direction. The natural tendency of the driver at this point is to press on the brakes harder, trying to get your car to stop faster, but the car has now lost control and you are just along for the ride. If you are an experienced enough driver, you can overcome this tendency and pump the brakes. As you can see, this will definitely make for longer stopping times. Even on dry roads, ABS can make a difference.
It does to an extent, but you still have to be careful when driving on icy roads, as I stated above.
    Advanced ABS systems may use more complex strategies and inputs to ascertain wheel lock (inertial measurements). In the case of ice, monitoring the wheel speed trend (acceleration and higher derivatives) could do it?
    – chilljeet
    Commented Jun 9, 2015 at 7:30
  • Hi Paulster2. Can you please help me understand about 'lock up'.. ? ".....During emergency stopping, without ABS, your front tires would have the tendency to lock up." Commented Mar 23, 2016 at 4:54
    @VijayMaximOff - Lockup refers to the point at which the friction coefficient of the brakes overrides what the tire to ground contact can provide and the wheel/tire stops going around (you hear the screeching noise). When this happen to both front tires, you lose the ability to steer the vehicle. If this happens to all four tires at the same time, you lose complete control of your vehicle. It would, in effect, be no different than sliding on ice for the amount of control you have. ABS prevents this by not allowing the brakes to completely lock up (some ABS systems allow momentary lockup). Commented Mar 23, 2016 at 20:41
  • Thank you Paulster2 for your simple explanation. Got it now Commented Mar 24, 2016 at 4:38
