I tried looking up everywhere, and this is unique to this bike.
Can someone identify the below component.
Looks like a pipe connecting the engine with starter motor.
Close up of the engine , both sides.
  • We need a bigger picture
    – Zaid
    Jun 4, 2015 at 13:11
    We need a picture with better detail, as in detail as to which part is actually being asked about. Jun 4, 2015 at 15:13
Oil Line
EDITED
I'm going to assume that you mixed up the arrow-head direction. The part is definitely not connected to the starter.
Though I'd earlier thought that it was for oil return from the Head , I believe it could also be some sort of reinforcement member. The bolts throw me off though, (could it be hollow to let the oil through?) You may need to look this up. I was able to find it on page 7 of the service manual online.
Part No. - M1010260
EDIT 2
Your bike has overhead camshaft. This is definitely the oil line running from the pump . The bolts, as I suspected are hollow bolts.
PS - I had to do this to a stranger's bike cause you wouldn't do it to yours.
Only kidding.
    Lol.. Yeah mixed up arrow head :-) , this thing has been bothering me since i got the bike 8 years ago lol
    – Shobin P
    Jun 5, 2015 at 9:53
  • @Anarach check the edit. Could you confirm the above ?
    – chilljeet
    Jun 5, 2015 at 18:10
  • Hmmm.. yeah thats the one
    – Shobin P
    Jun 5, 2015 at 20:24
  • @Anarach check edit . Hope you have your answer
    – chilljeet
    Jun 8, 2015 at 12:45
The arrow in the low resolution picture appears to point to the frame. The third picture shows the same side of the engine and a clear view of said frame.
