I have a 2003 Pontiac Sunfire
A tooth broke on a sprocket and my timing chain broke. I was told I have a bent valve and would need a new cylinder head. It's has been sitting for exactly a year.
What precautions should I take before attempting to drive again?
    Did you get it repaired already and are asking about future precautions, or are you asking about getting it repaired and back on the road? – Brian Knoblauch May 26 '15 at 21:23
As Brian commented, your question and the information we have is a little vague.
Not repaired already: It won't drive at all if the timing chain is broken. No amount of cranking the engine will start it. For this year/make/model it would probably be cheaper to either purchase another vehicle or swap in a low mileage engine than repair the current one.
If the engine has been repaired already:
  • Perform maintenance as required.
  • Keep away from too high of RPMS or 'redline'.
  • Don't 'bounce' off of the REV limiter; this is extremely harsh on the timing components.
