I replaced the mirrors on my Honda with LED mirrors after one of them broke off and I don't think the cables match, so I'm unable to control the mirror electronically. A few other sets of cables came with them with no directions and I assume they are extensions to the fuse panel. The cables on the original have sharp point male ends that plug into a few chosen points in a 15 or so pronged female connector. The ones provided with replacement look like something that would hook onto a brake cable. Also the end connectors on the extensions are single pronged as the fuse inputs require double prongs. I removed the original on the passenger side and it is still assembled with the end connector so I can follow the wiring pattern that way but I need to find a specialized kind of adapter.
Asked
Viewed
35 times
With the amount of information you've given, there is no way to answer this question. Have you tried looking at the manufacturer's website? At least post up exactly which make/model/type of mirrors they are, as well as vehicle information. I know you have a Civic, but beyond that, I don't remember. How about some pictures of what you're talking about? Give us something to go on, please, or I will vote to close this as unclear what you are asking. – Pᴀᴜʟsᴛᴇʀ2♦ May 25 '15 at 1:35
