When I add transmission fluid, it leaks out below. It looks like it is collecting around the pan, but also forward.
I am asking to see if someone thinks changing the pan won't cover the leak.
Update 5/25/15
Cleaned up around the pan and forward. The cork seal around the pan is bone dry. But it looks like the leak is coming from this rubber gasket. That's bad, right?
