While under load, the engine sounds like there is a bunch of marbles bouncing around in the engine. Revving the engine in neutral does not create the noise. Filling the gas tank with 93 octane instead of 87 "solves" the issue with the noise.
Filling up with 93 octane seems silly and expensive for such an old car. Some Notes:
  • Prior to the issue occurring the spark plugs were replaced while troubleshooting a misfire, that has been resolved. I double checked and the plugs are correct for the engine.
  • The car has the 1.8L engine and ~200k miles
Is it possible that this is an issue with spark plugs or something else?
  • Is that 93Octane measured by the American method? Or is that 93RON? May 18, 2015 at 7:47
  • @JuannStrauss I assume by the American method, I am in the US and I selected 93 octane at the pump instead of the 87 octane I usually use.
    – stoj
    May 18, 2015 at 12:39
  • From a quick google search, you should be using 91 at minimum. that would be about 95RON (if anyone else is interested). Though why it was working previously and now it isn't, I don't know. Was it particularly hot, or were you in slow traffic? May 18, 2015 at 13:11
  • I seriously doubt the 1.8L needs 91. That's the economy engine. There is probably something wrong causing the pinging, but the higher octane is preventing it for now. Beyond that, my 325i recommends 91, but if I run 87 it doesn't knock, I just get a little less throttle response, because the knock sensor protects the engine. The knock sensor may have failed in this case. May 19, 2015 at 2:13
  • @stoj Paulster2 is spot on with the answer. Did you try the solution, it WILL resolve the issue and you can go back to normal fuel octane saving tons of $$'s. Could you be so kind as to award Paulster2 with the answer? Thanks and I hope you tried the solution. as Paulster2 said, you'll be golden. Take care. Jan 4, 2016 at 23:22
Pinging is caused by one of several different reasons. It is usually a hot spot in the combustion chamber which is causing the issue. A hot spot is usually made of carbon buildup, the edges of which get hot very easily, will glow red as such, and will ignite the air/fuel mixture. If a hot spot is present, it will pre-ignite the air/fuel mixture during compression.
What you have to do is clean out the combustion chambers. The easiest and most effective way to achieve clean combustion chambers is to give your engine a SeaFoam treatment. Once the hot spot(s) in your engine are cleaned out, you should be golden.
  • I get the same symptoms (the engine sounds like there is a bunch of marbles bouncing around in the engine) and my intake manifold valves are covered in carbon blowby (as I just took it off for service). I'm curious how it got there, do you think from PCV ? Should I install a catch can between the PCV and intake to filter out oil from the recycled fuel ? Also, do you think this can cause engine overheating ?
    – amphibient
    Jun 19, 2015 at 20:40
  • @amphibient - Haha, you should ask your own question and refer back to this one if needed, lol! Jun 20, 2015 at 0:31
  • Man, i need an answer more than following formalities at this point
    – amphibient
    Jun 20, 2015 at 0:33
