My clutch pedal had absolutely no pressure unless I would pump it, but that wouldn't do much. It finally gave out so I changed the master cylinder next to the break cylinder with one that I know works for sure. It did, but when I woke up the next day I had absolutely no pressure at all. I know I don't have a leak because there's no fluid coming out of anywhere. What are my other options that it could be?
When you changed out the master cylinder, did you also change out the slave? If not, how well did you bleed the hydraulics? – Pᴀᴜʟsᴛᴇʀ2♦ May 12 '15 at 11:45
Yeah i never realized the bleeder on the slave and i blend it through there yeaterday and now its working great thank u for the quick response this website is awsome – Austin ruiz May 13 '15 at 12:41
Add a comment
Obviously the answer was to bleed the master/slave hydraulics.
If this helped and answered your question, please consider selecting it as the answer (check mark below the up/down vote). – Pᴀᴜʟsᴛᴇʀ2♦ May 13 '15 at 17:17
