Just got home from work and put my car into park and heard a grinding sound.
The parking brake stopped working. I tried putting it into drive and got the same grinding sound. It was as if something was scraping against the asphalt.
Any ideas?
    Have you looked under the vehicle to see if the is something dragging? Or was the scraping noise present without the vehicle moving? May 1 '15 at 20:12
    Yeah it does it without moving and gets worse when giving it gas. Almost seems like it's not quite getting into gear? I looked underneath to make sure nothing was dragging, that no rocks were stuck anywhere or that anything was bent/broken and checked all my fluids.
    – stephen
    May 2 '15 at 19:06
Check your e-brake drum shoes. They are located on the inside of the rear wheels. If the drum is rusted or the shoe (pad) is scraping it would make a scraping noise such as the one you described.
  • This could be helpful to some people, but in @stephen's comment he says the noise happens even without moving. Jan 11 '16 at 17:00
