On my car (2005 Dodge Grand Caravan) when I fill up my gas tank, almost immediately afterwards pulling out of the gas station my van sputters, misses, hesitates, call it what you will. The past couple of times the engine has actually stalled as well.
This is very short term. After this quick event it is then fine for the rest if the tank of gas.
Any thoughts on what could cause this?? Thanks!
EDIT
Some clarification on the symptoms, after I pull out from the gas state a few seconds down the road it's about a half second sputter/hesitation from the engine. And then it recovers. And then another few seconds later, the same hesitation will happen.
This is going from a really empty tank to a full tank. I always fill it up, and let it go down to almost empty (a few gallons left in the tank when I refill).
