Does anyone have any tips on how I can remove the front seat back panel from a Alhambra/Sharan 2014 registration?
Thanks in advance,
John
Sign up to join this communityDoes anyone have any tips on how I can remove the front seat back panel from a Alhambra/Sharan 2014 registration?
Thanks in advance,
John
Basically, you'll have to remove any head rest (if there), then there will be what is called "hog rings" which you'll have to pull (be prepared with new ones to replace). After that you can pull the cover off, starting at the bottom and pulling it back up over itself, so when it comes off it will be inside out. Then you'll have it off and you can replace the piece you are looking to replace. Goes back on in opposite order (easier said than done).
