I hit the ditch the other day and got towed out. There was no physical damage as far as I can tell, but whenever I indicated right, it would blink fast as if a bulb was burned out.
I replaced the front bulb, because it appeared to be burned out. But the new bulb didn't work either. Upon closer inspection, the old bulb's elements appeared to be undamaged, and the new bulb actually did still blink, but extremely dimly (and still fast).
Did the tow rope accidentally pinch (but not break) a wire while getting towed? Is it just a fluke with the new bulb and I should try another? Fuse? Any other ideas?
2005 Dodge Grand Caravan
