https://youtu.be/c4g_W9xNboQ video of it flickering. I've tested the output voltage of the 12v socket, and it's around 20v! Question about that here; Battery high voltage (multimeter was busted, volts are normal)
Whenever I am in neutral, or geared my screen flickers. It should only turn itself on when I am in reverse. In reverse, the display turns on fine and I can see the rear camera view, but when not in reverse, it starts flickering randomly. Any idea why this is happening?
