I measured my "cigar socket / outlet" with a multimeter. Instead of 12v it had 19v. Is this normal? Is it my voltage regulator, alternator, battery that has problems?
Car: Peugeot 307, 2.0 XSI 2003 The 12v "cigar socket / outlet" is off when my key is turned off, and on when I turn it on.
Additional information: Battery is almost 1 month old. Mechanic replaced it.
Voltage car off with key not inserted
Battery -  12v socket
16,67v     0v
Voltage car off with key turned 2/3 steps
not tested     18,2v
Voltage car on
20v        20v
Voltage car, airco, headlights on
20v        20v
    Did you check the voltage output at the alternator as well? Mar 28, 2015 at 11:31
  • I guess I should have first asked if the car was running or not (with key not just in the acc position) when tested? Mar 28, 2015 at 13:04
  • I've added additional information in my question above. Thanks Mar 28, 2015 at 14:36
    Are you sure your voltmeter is working properly?
    – Paul
    Mar 29, 2015 at 18:58
  • @Paul I am going to the mechanic tomorrow. I think and hope my multimeter is busted. Tested it with my power supply and it gave +2 volts readings. Still the car battery would be too high, even with +2 volts wrongly added volts.. Mar 29, 2015 at 20:29
Went to the mechanic, and the voltage looked good at 14,4v +- when everything (car, airco, lights, radio) were on. Looks like my multimeter is busted. Need to buy a new 9v battery for my multimeter to test if that fixes the offset, or I'll try to calibrate my multimeter.
Anyways, always test with another multimeter if in doubt.
    You can also test on a known source, which is a procedural requirement for professional electricians.
    – Paul
    Mar 31, 2015 at 21:45
  • Yes, I did that and it gave wrong values. Even with a new battery + some calibration it still has big differences. Time for some a new multimeter. Apr 1, 2015 at 18:00
