I have some weird scraping/rubbing noise in my right front wheel. I I hear it regardless of weather i brake or not, and the slower i go the more low pitched and grindy it sounds. It continues to scrape at normal driving speeds, but is very high pitched and not very noticeable. I do not hear it as much while in reverse.
what I have checked/tried.
brakes look ok, the caliper must be sliding properly since there is even wear on both inside and outer pads.
rotor looked pretty good but possibly warped.
I replaced the front brakes and rotors, but am still hearing the noise
It occours less when I am in reverse, or when Im turning right. It is more apparent while turning left, but it is happening all of the time.
so at this point I think it might be a wheel hub bearing, but it's not 'wubwubwub' noise everyone describes it as.
Here's the noise: https://www.youtube.com/watch?v=pN30O-m8CpY
