My car is making an odd noise, which you can hear in this video.
It only makes the noise as soon as I turn the car on. Can someone let me know what it is?
The ABS light has also come on.
    What is the make, model and year of the vehicle? Have you had the codes read? Mar 15 '15 at 15:23
With the limited info available it sounds like the ABS pump running. I can't think of anything else that cycles that fast. Why it would be running at start up I haven't a clue. You could try pulling the ABS fuse and see if the noise stops.
  • Agreed with pulling the ABS fuse. I'm betting the pump is stuck in diagnostic mode where it cycles to do a self test, but is failing. Mar 15 '15 at 21:14
