I just bought a 8" bench grinder from Harbor Freight to clean up some automotive parts with a wire wheel. On the left side of the grinder has a left hand threaded nut on it, while the other side has a right hand threaded nut. If I use two wrenches and try to tighten one side the other side will loosen. No matter how much I try this loosing/tightening thing keeps going back and forth. There is no special tool included and there doesn't seem to be a good place to hold the shaft in-place. Is there some special trick to get these wheels attached and secured?
2Whomever voted to close, remember that we have had questions about tools asked on here before, most recently about breaking a ratchet due to hammering on it ... – Pᴀᴜʟsᴛᴇʀ2♦ Mar 9 '15 at 23:59
The hand-held grinders I have used have generally had a button that pushes a mechanical pawl in to lock the shaft - I presume this doesn't? – Nick C♦ Mar 10 '15 at 10:33
It doesn't have a locking button or mechanism. – Harry Glinos Mar 10 '15 at 16:22
Add a comment
I am not sure if OSHA would approve but the method I use is to wedge a screwdriver between the toolrest and the wheel. Then tighten the nut. It doesn't need to be jammed in real tight just enough to snug up the nut.
