I am hoping to find an enthusiast who knows a bit about classic Fords.
Can anyone identify these vintage Ford hubcaps ?
  • What is the diameter of these? The bottom seems a little wider, but both are about the same. I just cannot get an exact size to help match them. The top pattern appears to be common to the 1930's, if that helps, but the one which appears to match it is about 5.75" ... it appears this one is bigger than that. Feb 20, 2015 at 21:24
  • @Paulster2: I'm afraid I couldn't say: I found this image out of context! Feb 20, 2015 at 21:27
  • @Paulster2: what about the finish? It looks painted to me. Could they be replicas? Is there a museum I could contact? Feb 20, 2015 at 21:29
    Well, here are the two which I believe they are for ... looks about as close as you are going to get: top hub cap and bottom hub cap if that helps. Feb 20, 2015 at 21:29
    @Paulster2 That comment should be an answer Feb 20, 2015 at 22:03
Well, here are the two which I believe they are for ... looks about as close as you are going to get: top hubcap and bottom hubcap if that helps.
Yes, they look as though they have been painted over. I would bet Henry would have had a fit had these come off the assembly line looking like that ;-)
