I was pulling up my drive this morning when my horn started blaring non-stop.
I got out and pulled the horn relay to make it shut up. I tested the relay and determined that it was working fine, and just noticed (now that it's getting dark and I can see them) that my tail lights are also stuck on (the tail lights, not the actual brake lights which still work if I push the brake pedal). I removed the fuse for those temporarily so that my battery will still be alive tomorrow.
Is there somewhere that these circuits might be shorting? Or is the horn some sort of weird intentional side effect to let you know something else was wrong (the internet suggested this, but it seems ridiculous that they would design it this way to me... who wants the horn to be going off until you can fix another problem unless it's something dangerous that they're trying to get you out of the car for)? Or is there some other diagnostic step that I should try next?
This is all in a 2001 Honda S2000.
Update: Last night I was driving back home after dark, so I put the tail light fuse back in. When I got home I killed the power, and was about to go remove the fuse again, when I noticed the tail lights had gone out properly. I put the horn relay back in, and that seems to have started working again too. It looks like whatever the problem is, it's transient. What would a shop do to find the problem at this point?
  • Tough luck, Sam. I see you've posted out on forums about it as well, so I know you've looked at the internet like I just did. I'm thinking there is a short somewhere. I'm thinking you are going to have to trace the wiring from the fuse box back to the object, then I doubt they are interrelated. If so, the tail lights would have gone off when you pulled the fuse for the horn (or visa-versa). Edit your question with whatever you try and we can help you with further diagnostics and maybe get it narrowed down. Feb 7, 2015 at 14:47
  • @Paulster2 Thanks; I've poked around a bit with a multimeter, but didn't find anything irregular (other than constant power to the horn / tail lights, obviously). I'll keep looking and let you know if I find anything else.
    – user3729
    Feb 7, 2015 at 19:13
  • @Paulster2 et al. slight update added to the question (which makes me less hopeful of finding the problem).
    – user3729
    Feb 8, 2015 at 12:46
    Grounding issues create all sorts of weird issues. Try to check the main ground wire resitance against the chassis to see if you find any with too high values.
    – Elias
    Feb 10, 2015 at 16:12
Though I can't prove it (I haven't been able to reproduce the problem to confirm), I think I may have found the answer to my issue (thanks to Elias' comment).
I realized recently that I only noticed that the issue had disappeared after I had installed a separate, unrelated, electrical system which required that I add a new fuse (I cheated and used one of those "add-a-circuit" fuse-splitter things). I grounded that circuit on the same bolt that the rest of the under dash fuse box is grounded to.
There's a chance that the ground was bad there, and when I added the new circuit I tightened that bolt down and fixed the grounding problem. I don't have a circuit diagram in front of me to see if this is even remotely possible (eg. if the horn is actually grounded there), but since the problem disappeared and hasn't come back, and that's the only other work I've done, I'm currently assuming that it was a grounding issue on the under-dash fuse box.
