We just got ourselves a new Skoda Superb with a reversing camera but it doesn't show the distance lines that apparently should appear on it.
We test drove the Passat and saw it had distance lines on it and the Skoda manual also shows distance lines on the reversing camera but our new car doesn't show them – and I may be noobing it up, but I can't find any reference in the manual as to how to turn them on.
Any help at all would be appreciated! Thanks.
I think you can turn them on/off using the touch stuff found on page 38 of the manual you gave a link to. Here is an excerpt from it:
Looking at Figure 15 (on the left), it says to change the display to use G (bottom right hand corner of the display), which then flips you over to Figure 16 (on the right). Then try using A (upper left) on this screen or possibly B (upper right). If all else fails, you can look in the Vehicle Owner's Manual, in the chapter Assistance Systems. You might also try turning the camera off (G), then back on again. This may reset the camera and settings to factory standard.
  • Pressing A turns on F. Pressing B shows G, H, I and J. No luck so far - we'll probably have to contact the dealer.
    – dlanod
    Jan 10 '15 at 6:58
