This question already has an answer here:
I was in a motorcycle accident and when I crashed my knee dented my tank on impact. Needless to say my knee is pretty bad but my tank only has a dent in it.
Is there a trick for removing a large dent from my gas tank? It's steel and kind of small (~2.5 gal).
I've heard of shoving a motorcycle tube in the tank and then inflating the tube. And I've heard of pressurizing the tank too but if anyone else has any ideas I'm willing to consider them.
marked as duplicate by DucatiKiller, Fred Wilson, Zaid, Poisson Fish, cdunn Jan 26 '16 at 15:16
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • Call your local body shops and larger motorcycle shops to see if they think they can remove the dent with special tools. Cost can be minimal if it's just a suction type job. – Paul Dec 29 '14 at 20:32
There are only two ways I can think of to remove the dent. One is to put a certain amount of water in the tank (off the bike, of course), and freeze it. I don't know what that "certain amount" is, though. If you put too much water in it, it will split seams and such, so proceed at your own risk.
A second method is to heat the area up with a blow dryer, then hit it quickly with a computer duster compressed air can which is turned upside down. Metal has a memory. When you run it through the quick heat/cool process, it tends to go back to its original shape. Depending on the size of the dent and if there are any creases in the metal will ultimately affect the outcome of how this might work. A crease will not come out this way. It may take several heat/cool cycles to get it all the way out.
There is a third way, but that involves buying a new tank, and I guess a fourth of taking it to a body shop to have them do it.
    I like that second method. I remember someone mentioning it. I'll give it a shot. – gh0st Dec 29 '14 at 2:28
