I have a problem with my car it won’t start. Just a little background on my car, I have a 2008 Nissan Versa and I have a cold air intake installed in my car with a hydro shield covering the air filter and the area is fully cover by fender lining sides and bottom.
Prior to the car not starting I drove in the rain to get gas from Valero (I usually go to Arco) to work and parked my car outside for 6 hours and started the car with no problems and drove home. The next day I reparked my car in the garage again no problems except I smelled gasoline when i stepped out of the car and left the car in my garage for a whole day. The following afternoon I turned on my car and it cranked and sounds like a whirring sound but car won’t start.
I had it towed to the dealership and they did a engine diagnosis and couldn’t find anything wrong but took off the starter to give to the shop to have it tested. He also mentioned that there could be water in the engine because I do have a cold air intake, but I don’t believe it could be hydrolock because I didn’t drive through a flood or deep puddles. What are your thoughts on why my car won’t start? Thank you for reading!
