Is it difficult? How do I know the exact location? Just purchased a replacement but I want to make sure I'm opening up the right compartment.
3.5L V-6
This is a picture of what I believe it is. enter image description here
No that's not the location. It's in the thermostat housing (attached to the engine) that the outlet radiator hose attaches too. This hose runs from the right side (passenger side) of the radiator to the engine.
  1. Drain the cooling system
  2. Remove the air cleaner outlet duct
  3. Remove the radiator outlet hose from the thermostat housing enter image description here
  4. Remove the bolt and bolt/stud holding the housing
  1. Remove the thermostat
  2. Clean the gasket surfaces
  3. Install new thermostat
  4. Install new gasket, with gasket sealer if you prefer.
  5. Install in the reverse order, Making sure not to over torque the bolts. Spec is 10 N.m (89 inch pounds) or about 7 foot pounds. IE snug or you'll strip the threads out of the block.
  6. Fill with 50/50 DEX-COOL and distilled water.
Picture Source
  • The upper radiator hose attaches to what's in the picture. Can't figure out where the housing is
    – munale
    Dec 24 '14 at 18:21
  • @munale That's the inlet hose you are looking at. The thermostat is in the outlet hose. Just to the sideof the oil filter and above the AC compressor Dec 24 '14 at 18:24
  • @munale Found some pictures and added them to my post. Let me know if you need anything else. Also if this post was helpful for you please up-vote and ultimately accept the answer (check mark) if it completely answered your question. This helps future visitors know that the answer worked for you. Dec 24 '14 at 20:32
I never located the thermostat but opening up the inlet house and putting back seemed to clear some air out and now it works fine
  • Was it different that the pictures I posted? Jan 1 '15 at 18:51
  • It appears so. Or maybe it's just too far down for me to see
    – munale
    Jan 1 '15 at 18:56
