How can I add a new key to a Daihatsu immobiliser?
The key I have has a Texas 4C transponder, and is used in the Daihatsu Copen and Daihatsu YRV (to name just two).
Sign up to join this communityIf you have the black "master" key that came with your Daihatsu, adding new keys is simple. You will need to have all your keys ready, as these steps will remove all keys from the immobiliser ECU with the exception of the black master key.
These steps will work for the Daihatsu Copen (pre 2013) and the Daihatsu YRV
Terminal T is OBDII pin 13 and terminal E is OBDII pin 4
