My 2001 Lexus IS200 is about to hit 100 thousand km and I am about to change the oil, oil filter, air and cabin filters. My question is, do I need a new fuel filter this early in the life of the car? It's been using Spanish gas all its life which is not the worst out there, I guess. I have tried to find Lexus recommendations on it but to no avail. Any hints? Thanks a lot in advance for the help.
The fuel filter on your vehicle is part of its fuel pump in the fuel tank. They are designed and made to last the 'life of the vehicle'. They have a plastic OBD2 fuel tank with an interior 'bladder', which means unless something other then normal operation causes damage they never have to be changed.
What do you mean by bladder - does it self clean? If so where does it throws all the junk from fuel?– MatissJun 19, 2019 at 12:36
If it's never been changed, then yes, I'd change it. To get 100k out of a fuel filter is a good life for it. Fuel filters are usually not too expensive, so are a decent maintenance item to take care of. They are also usually fairly easy to change ... usually.
