The tire is worn on only on side, suggesting incorrect camber alignment. However, the amount of wear varies along the rotation of the tire.
Does the fact that the wear is not even for the entire rotation point to some other suspension issue or is it more likely the result of just alignment, alignment+balance, etc?
