i have Toyota Surf 3.0 L . i need to visit the places which are plus 4000 meters (15000 feet). do i need to use low octane fuel or do i need to increase the intake of fuel due to high altitude and less oxygen. please explain in detail.
Carry on using your regular fuel. The BARO in your engines ECU will adjust for altitude, and O2 sensors and MAP will keep the engine running sweetly. You may notice a small drop off in power but it will not be enough to be unduly concerned.
