I have 2001 Hyundai Accent L 1.5 liter, 4 speed stick shift. The Check Engine light is on. The code that is coming up is "EVAP under lean P1128 Fuel Trim Lean". All other monitors are good.
I need to get the car registered immediately. How do I run a drive cycle on this car? The only procedure I can find is for a automatic transmission. What else do I need to fix the CEL code?
