I have a 2003 Dodge Ram 1500 with a 4.7 magnum, and I have replaced the radiator, thermostat and water pump. I keep having to fill the reservoir every couple of days. Fluid keeps coming out of the over flow tube. Any suggestions on what could cause this?
Coolant coming out of the overflow is a sign of over-pressurisation. The cheapest cause of this is the pressure cap failing - have you replaced that?
The other main causes of it are overheating, or gas getting into the system and so increasing the pressure, usually through a head gasket breach between a cylinder and the water jacket.
Have you noticed any signs of overheating? If not, it might be worth doing a compression test on the cylinders to look for signs of a head gasket blow.
