10
I took my car (2006 Honda Civic) to firestone to get an oil change and they told me I should get the fuel injectors cleaned. I was in an Advanced Discount Auto Parts store the other day and I noticed that you can buy a bottle of fuel injector cleaner that you can pour down your gas tank. Is this what firestone would do or would they do something that you can't buy at at store?
3 Answers 3
12
The "correct" way to clean fuel injectors is to take them out and use some specialised equipment that also allows you to check the injector's spray pattern and flow, which I doubt Firestone will have - usually only FI specialists do have that sort of kit.
My guess is that they were trying to sell you some overpriced additive that you can buy at the store and pour into the tank. At a stretch the might have the sort of injector cleaner that you hook into the fuel system and run cleaner through that way. The latter is better, but still doesn't allow them to check if the clean was actually effective because the injectors stay where they are...
Did they actually say why they thought your injectors needed cleaning (apart from their bottom line, obviously)?
If you think they'd benefit from cleaning, I might be tempted to spend $10 on a bottle of Seafoam, Techron or other injector/fuel system cleaner and pour that into the tank. That'll still save you a lot of money compared to what Firestone would be asking to do more or less the same thing.
Also, in a lot of cases when people recommend that you clean the injectors, you're better off at checking/changing the fuel filter if that hasn't been changed recently. That's something that's overlooked often and tends to have more of an impact on fuel flow than deposits on the injectors.
  • They didn't say anything was wrong with it. They just recommended it and said my car would run better.
    – Xaisoft
    Commented Sep 22, 2011 at 16:08
    Sounds to me like their bottom like would run better then :). If you want to try their theory, get a bottle of injection cleaner and pour it into the tank to see if it does make a difference. Commented Sep 22, 2011 at 17:15
    This is very good and detailed post. I just want to make a comment on "When people recommend that you clean the injectors..." -- you need to carefully consider WHO the people are. For places like firestone (and even your dealership) selling "injection cleaning service" which as this answer stated, is just a cheap fuel additive, is basically pure profit while providing almost no value to you. So in these cases, when tire place recommends X, where X has nothing to do with tires, I'd suggest to simply walk away.
    – DXM
    Commented Oct 8, 2011 at 7:48
    Although in many modern cars, there is no serviceable fuel filter; it is built into the fuel pump. Commented Jul 10, 2013 at 5:07
I would advise against using any kind of additive or cleaner. Your best bet is to send it to a professional injector cleaning service.
When my car hit 100K miles, I sent the injectors to this place this place. Was fast and inexpensive though you have to live your car being down for about a week. He even gives you a comparison of how fuel flowed before and after.
  • another option is to go to junk yard and buy another set of injectors. When my integra with 150k needed them, I bought 4 for $7 a pop. You spend a little more, but your car is off and back on the road in 1 hour.
    – DXM
    Commented Oct 8, 2011 at 7:50
They need to be taken out and cleaned. It's a relatively inexpensive job. Where I live, it costs halfway between a minor and major service for a small car. Best thing would be to ask them to do it the next time you have your car serviced to save on labour.
