I can imagine lots and lots of reasons why a MotoGp helmet is desgined that way. Aerodynamics and multiple layers of protection being the main reason. But a motocross helmet has its front pointed. And a sunshade(it seems). How aerodynamic is that anyways? In case if the rider should fall on his/her nose, the long pointed end of the helmet may prove to be counter-productive and it might hurt/break the neck. But i can guess why do they insist on using goggles instead of visors. Is that the reason? That a person can use goggles which fit perfectly inside the MotoCross Helmet?
It's all about safety for the specific requirements of motocross.
In motocross you do not want the weight of a full helmet when you are coming down off a jump, so the lighter the helmet, the less strain on your neck.
  • The peak is designed to snap off in the event of a crash, so that is not a problem.
  • Aerodynamics are also not an issue - motocross speeds are relatively low.
| improve this answer | |
  • +1 for "The peak is designed to snap off in the event of a crash" – You_Shall_Not_Pass Nov 3 '14 at 9:24
  • I would think the "peak" (I would call it a bill) is there to protect the rider from debris kicked up by other riders. – Pᴀᴜʟsᴛᴇʀ2 Nov 3 '14 at 11:45
  • That is true - the peak does a bit of that (ie stopping falling debris catching the rider by surprise while they are looking down at the ground) – Rory Alsop Nov 3 '14 at 12:31
