On a 2005 Lexus RX330:
P0304 Cylinder #4 misfire.
What is the cause and is it a big job to fix?
P0430 Catalyst system efficiency below threshold - Bank 2.
Is this a big job?
Is it OK to run the car without fixing them?
  • They were changed in April,2014 so about 10,000 km. All are irredium.
    – ahamed
    Nov 4 '14 at 1:13
  • no. The problem has been solved by changing one coil and cat repair.
    – ahamed
    Nov 15 '14 at 23:16
The OP resolved this issue as per his comment:
So the reason for the misfire was a bad coil, while the catalytic converter had to be "repaired", possibly replaced due to clogging.
