I knew I had a minor vacuum leak, but it got worse all of sudden while at a stoplight.
In trying to get through to the next block, the engine started to knock. (My guess is preignition thanks to the air/fuel ratio being off)
Now when I turn it on in neutral, the idle is intermittent and sometimes turns off but there is no sign of knocking.
First gear, however, is a no go.
The car did have a vacum leak (which the mechanic fixed), but it came back again.
  • Was wondering why did this leak come back again?
  • Is there another reason for it occurring?
  • Why is it sometimes better when the engine is started cold? (Tighter rubber?)
  • Furthermore, is there any other inspection I should do because of the knock?
There are no check engine lights.
-1
Preignition occurs when a hot spot inside the combustion chamber ignites the fuel before the spark does. The exhaust gas recirculation system (EGR) dilutes the air/fuel mixture slightly to lower combustion temperatures when the engine is under load. This reduces the formation of oxides of nitrogen and also helps prevent detonation. So, I would check the operation of the EGR valve and system.
  • On a 1991 BMW E30? EGR valve? Nov 23, 2015 at 12:08
