I think you need to do a throttle position sensor recalibration (reset).
(NOTE: I will post several different adjustment versions. I believe the top one is what you need (for a K8 engine), but will include another four depending on your engine.)
To do this for your vehicle you need to follow the steps below, depending on whether it is a stick/auto and which engine (SOHC or DOHC). I will include all the different descriptions:
1.8L (K8) Engine:
- Detach the connector from the throttle position sensor.
- Connect an ohmmeter between terminals IDL and GND.
- Rotate the throttle linkage by hand. With the throttle valve fully closed, the ohmmeter should read 0.1-1.1 volts.
- With the throttle valve fully open, the ohmmeter should read 3.1-4.4 volts.
- If not as specified, adjust or replace the throttle position sensor.
SOHC Manual Transmission:
- Connect an ohmmeter between terminals IDL and E.
- Insert a 0.004 in. (0.1mm) feeler gauge between the throttle stop screw and stop lever.
- Verify there is continuity between terminals IDL and E.
- Then replace the feeler gauge with a 0.02 in. (1.0mm) feeler gauge, verify there is no continuity between terminals IDL and E .
- Then open the throttle wide and verify there is no continuity again between terminals IDL and E.
- Next, connect the ohmmeter between terminals POW and E.
- Verify there is no continuity between terminals POW and E.
- Then replace the feeler gauge with 0.02 in. (1.0mm), verify there is no continuity between terminals POW andE.
- Then open the throttle wide and verify there is continuity between terminals POW and E.
- If not as specified, adjust or replace the throttle sensor.
SOHC Automatic Transmission:
- Insert a 0.024 in. (0.6mm) feeler gauge between the throttle stop screw and stop lever.
- Verify there is continuity no between terminals IDL and E.
- Connect an ohmmeter to the throttle sensor terminals Vt and E.
- Verify that resistance increases as throttle valve opening increase.
- With throttle valve fully closed the resistance should be below 1 kilohm and as throttle valve is fully opened resistance should increase to approximately 5 kohms.
DOHC Manual Transmission:
- Then replace the feeler gauge with a 0.027 in. (0.7mm) feeler gauge, verify there is no continuity between terminals IDL and E
- Then replace the feeler gauge with 0.027 in (0.7mm), verify there is no continuity between terminals POW and E.
DOHC Automatic Transmission:
- Connect an ohmmeter between the terminals IDL and E.
- Verify there is no continuity between terminals IDL and E.
NOTE: These procedures were pulled from AutoZone.com and are specified for the Protege which should be the same for the Lantis 323, as these are supposed to be the same platform and engines.
The TPS should look something like this:
The connector face should look something like this:
Other things to do if this doesn't work would be to clean the throttle body area (inside/out) completely. Also, consider changing out the before cat O2 (lambda) sensors. If these are lazy, you would see a large increase in gas usage.
EDIT: One other thing to check is to ensure you don't have any vacuum leaks ... completely forgot to mention this. I'd specifically check around areas where the work was done, like at the throttle body. This might account for the higher than normal RPM as well as the high gas usage. When the O2 sensor "sees" the higher than normal oxygen level in the exhaust stream, it dumps more fuel into the mix and your gas mileage suffers. Seems like it would be the other way around, but it happens.
