My Acura TSX is reaching the 100k miles range soon and I'm looking to get advice on maintenance changes. Thanks in advance for your help!
I received this information from this site. It is the 100,000 mile maintenance service specification for the 2009 Acura TSX.
Action: Description
Inspect/Adjust/Change Rotate Tires
Inspect/Adjust/Change Replace engine oil and filter
Inspect/Adjust/Change Inspect windshield wiper and washer systems and fluids levels
Inspect/Adjust/Change Inspect suspension components
Inspect/Adjust/Change Inspect steering linkage
Inspect/Adjust/Change Inspect power steering fluid level
Inspect/Adjust/Change Inspect half shaft dust boots
Inspect/Adjust/Change Inspect exhaust system
Inspect/Adjust/Change Inspect engine accessory drive belt
Inspect/Adjust/Change Inspect coolant recovery reservoir
Inspect/Adjust/Change Inspect clutch operation
Inspect/Adjust/Change Inspect brake fluid level
Inspect/Adjust/Change Inspect automatic/manual transmission fluid
Inspect/Adjust/Change Inspect air cleaner/element
Inspect/Adjust/Change Check turn signals and hazard warning lights
Inspect/Adjust/Change Check shocks and struts
Inspect/Adjust/Change Check radiator, coolers, heater, and A/C hoses
Inspect/Adjust/Change Check battery, exterior lamps, and horn operation
Inspect/Adjust/Change Replace spark plugs
Inspect/Adjust/Change Replace PCV valve
Inspect/Adjust/Change Replace coolant
