Is it possible to to repair or replace the plastic eyelets which connects the regulator the door glass glass?
    Not sure I'm seeing what you are describing. Can you show some pictures of the area you're talking about with a little more detailed description? Sep 20, 2014 at 15:50
You can buy the plastic clips on eBay from around £2($4) the pair. The plastic does not stick well enough, even with super glue. Not really a repairable item.
