I need to replace some fuel lines (from the injector control to the injector) on my 93 VW Cabriolet. The site that sells the lines has 2 options for the 'Injector Size': M10 x 1.00 or M12 x 1.5.
I'm not sure what either of these mean or how I can check to see which one my injectors are.
Can anyone point me in the right direction? Thanks!
Those are metric screw dimensions. M10 means a 10 millimeter outer diameter for the bolt or whatever piece it is; M12 means 12 millimeters. The part after the 'x' is the pitch -- how many mm a thread is wide.
To figure out which you have, you can measure the existing part with calipers and a thread gauge. You might also try calling your local VW dealer with your VIN handy; actually I'm surprised that the website you're purchasing from doesn't tell you which you need based on the VIN. You might look into that a bit more, or try another site or two.
| improve this answer | |
