It seems that the axle nut on a 2001 Honda Shadow are different sizes on either side of the bike. What size are these so I may get the correct wrench to work with them. I have tried other sources and I couldn't find an answer.
Axle nut is 27mm and the other side is hex head 24mm, this was on a 2002 - it should be the same from 2000 to 2007.
Confirmed axle nut size on friends 2001.
