So i got in the car this morning, and it felt like i still had my handbrake on when i pulled off. Check that, it wasn't on. Drove on a little bit thinking i was imagining it, finally accepted it was definitely a problem, turned round and came home.
Walked round, and immediately felt the heat radiating from the offside rear wheel. Put the car on stands, wheel off, and i played around with the metal lever that the handbrake cable attaches too, i noticed that the spring that pulls it back to the original position (and releases the pads from the disc) wasn't pulling it back all the way.
I pushed that metal lever another 5 or 10 mm (my measurement by sight is as bad as my mechanics) and the disc free'd up and started to spin (admittedly it was still catching a little, but i think thats because the disc is slightly warped to be honest, my brother said it looked warped anyway!).
So i guess my question is, how possible is it that the spring has worn out, and that it's unable to fully retract itself and pull the lever all the way to release the brake pads from the disc? Or is this a red herring, and that lever doesn't have to go all the way back in order to release the disc, and there's a build up of grime or another problem elsewhere?
If these springs do wear out over time, how easy are they to replace. I checked the EPC for my motor, and i cant find a part number for the spring anywhere! The closest i've come to finding a replacement part is one forum thread that mentions someone having to go to the VX parts desk for a replacement spring?
At the moment i'm half and half as to whether to continue the DIY route and hope a spring works, or wether to bite the bullet and just get a professional in to take a look
Car is a Vauxhall Vectra 1.9CDTi (2007 reg plate) if that makes any difference
Any help or advice would be appreciated :)
