I was wondering about this the other day. Is the petrol usage in the car only influenced by the position of the gas pedal?
So for example if I take my foot of the gas and coast for 30 seconds, would that be the same petrol consumption as sitting idle in traffic for 30 seconds? Or if If I'm driving through a slow zone with the gas pedal 30% depressed, over a minute would that be the same gas consumption as driving on a motor way in top gear with the gas pedal at 30% depressed?
Do slopes / hills have an influence? Assuming I'm driving up a slope in a high gear with the gas pedal in a constant position. The vehicle slows but gets to the top then proceeds as normal. Did the hill influence consumption or was it constant because the pedal never moved?
Lots of things influence fuel consumption, actual pedal position being probably the strongest. The engine's rotational speed has SOME influence, but not nearly as much as pedal position... and a lot of the reason that the engine's speed has influence is because ignition timing will be different at different engine speeds (among other secondary influences), and ignition timing also influences fuel consumption.
Coasting, with the transmission shifted to neutral is exactly equivalent - in terms of fuel volume per unit time - to idling. Coasting with the transmission engaged is less efficient than idling because of compression braking.
Slopes DO have some minor influence, because slopes alter engine speed (engine speed falls on upslopes, rises on downslopes), but GENERALLY if you hold the pedal exactly fixed (or just use a once-common accelerator lock) fuel consumption on downslopes should be very similar to fuel consumption on upslopes. Too, fuel pressure falls off slightly on upslopes, and that change in fuel pressure exerts some minor influence. Weight shifting to the front or rear tires will even influence the tires' rolling resistance, which will affect fuel efficiency.
If we examine ALL the details, we'll find countless influences, most of them minor-to-negligible.
| improve this answer | |
    You really need to look into how engine braking and fuel consumption are directly related. I believe your reasoning has to do with carbureted engines and not with newer fuel injected ones. I would also like to see references towards up/down hill motoring having influence on fuel pressure. – Pᴀᴜʟsᴛᴇʀ2 Aug 15 '14 at 14:52
    Pretty much any fuel injected engine will cut the fueling when coasting with the throttle closed if the revs are above a certain level (ie ~idle speed). This isn't so much running lean, as not running at all. – Kickstart Jan 30 at 9:21
    @TDHofstetter - I tend to avoid automatics (far prefer a manual gearbox), but many modern models in Europe now use automated manual boxes which rely on an ECU to control the clutch (or clutches on some), with no need for a torque converter. – Kickstart Feb 10 at 9:30
    @TDHofstetter, with older automatics I tend to miss the direct link from the engine to the road, and I like the control of a manual. The auto manuals did appeal, and while they can no doubt change gear far more quickly than I can I found it frustrating to be sitting there doing nothing waiting for it to change; at least with a conventional manual I am doing something. – Kickstart Feb 12 at 9:00
    @Kickstart... one, of course, must wonder whether (unless one is in a high-stakes "high-tech" competition) that 1.2mS difference in shift time is actually worth anything, particularly given that it requires a great deal of extra complexity and a great deal of extra electricity / fuel. Yet one more example of modern insanity. 8) – TDHofstetter Feb 13 at 15:54
There was a thread on here entitled Fuel Consumption and other Fuel related data from basic OBD-II parameters where the author was concerned about fuel consumption. While the question was never "answered", there was an article posted which sheds light on your question. It is a PDF entitled Estimation of Fuel Consumption using In-Vehicle Parameters, by Min Goo Lee, Yong Kuk Park, Kyung Kwon Jung, and Jun Jae Yoo (sorry, I need to give the authors credit here). Their purpose in the article was to estimate fuel consumption through the OBD-II system.
What, you ask, does this have to do with your question? The two main factors these individuals used to provide their datum is RPM (engine speed) and TPS (Throttle Position Sensor). In their article, they provide a couple of graphs which are very telling. The first graph (which is their figure 8), shows Fuel Consumption versus engine speed.
Image from article mentioned above.
Each one of the blue "X"'s is a data point. The first time I looked at this graph, I was perplexed as to why there would be a bunch of data points showing no (ie: zero, zed, nil, none, nada) fuel consumption between ~1000-1500 rpm. Then I realized when a vehicle is coasting with the foot off the throttle, fuel consumption goes to zero at some points because fuel is not needed to keep the engine turning (ie: engine braking to an extent, but not quite). This is one way auto manufacturers use to improve fuel consumption. This is why engine braking uses less fuel than coasting in neutral. In every vehicle which utilizes Electronic Fuel Injection (almost every new automobile on the market today uses some sort of EFI), there resides in the computer a fuel map. The Powertrain Control Module (PCM - also known as Engine Control Module or ECM, etc.) takes input from several different sensors located on the engine. These sensors read such things as the engine coolant temperature, air intake temperature, manifold pressure, amount of air coming into the engine, as well as the throttle position, engine RPM, vehicle speed, and which gear the transmission is currently engaged (mind you it reads other input as well, these are just some of the main inputs ... each vehicle manufacturer can do their own thing differently). The PCM takes all of these inputs, shuffles them through algorithms, and comes up with the precise amount of time to leave the injector open.
This next graph, shows the relationship of throttle position to fuel consumption:
This graph indicates that fuel consumption is very linear to throttle position. You can expect the further you press on the pedal (and thus affect the throttle position), the more fuel you are going to use.
With these facts in mind, let's try to answer your questions:
If I take my foot of the gas and coast for 30 seconds, would that be the same petrol consumption as sitting idle in traffic for 30 seconds?
To me, it is obvious, sitting idle is going to get the worst fuel economy. Why? Because you are not moving. If one of your input factors in figuring fuel economy is distance traveled, in this case "0" (nil, zero, zed, nada, null) ... you've used 30 seconds of fuel keeping the engine running to achieve nothing, except for wasting fuel. Travelling any distance in the 30 seconds, regardless of engine or vehicle speed, is going to produce better fuel economy than sitting still. This is why some manufacturers have introduced systems in their vehicles which allow the engine to completely stop while sitting at a stop light, then as soon as you release the brake and step on the gas, the engine fires right back up and away you go.
You are forgetting a few major factors here, one of which is vehicle speed versus engine speed. Remember, as you go faster (at least with an automatic gearbox), the transmission will shift up into another gear, until the transmission is either in the top gear, or in a gear consistent with the desired vehicle speed. So say, at 30mph, the engine is running at 2000 rpm (these numbers are just thrown out here for demonstration and may/may not actually be accurate) at your 30% throttle. Your engine will have turned a total of 1000 rotations and your vehicle will have traversed 1320 feet. Now, at highway speed (70mph) with the engine turning 2000rpm and 30% throttle, your vehicle will have traversed ~3080 feet. You should realize that as you go faster, other factors come into play. First, you only have so many gears in the gearbox. Once you've reached the top gear, that's all you have. At that point, in order to speed up, engine speed will have to increase. All vehicles are different as to wind resistance, so as you go faster, the air around the vehicle also starts to play a factor. The faster you go, the more wind resistance, and the more throttle you'll have to depress in order to maintain that speed (or go faster). All of this affects the fuel consumption. There is a point of diminishing returns as to vehicle speed versus fuel consumption.
NOTE: Please remember, when you are traveling a given speed (say 70mph), your throttle position will be much less than 30%. It doesn't take very much horsepower to keep a vehicle traveling at a constant speed. Your throttle will not need to be open as much in order to maintain that speed. The major factors in reference to your throttle position will be whether you, the driver, command the vehicle to speed up or slow down. Driver input is given directly through the throttle.
Absolutely. As described above with the graphs, if you are going down hill and do not want to go faster, the first thing which you do is take your foot off of the pedal, which reduces your throttle position to 0%. The vehicle computer registers this and after a given time, will reduce the injector pulse width to zero allowing the momentum of the vehicle to keep the engine turning (through the gearbox). As soon as you open the throttle any given amount, the computer will start throwing fuel back at the engine. Mind you, this is a very simplified version of what really happens and each vehicle manufacturer is going to do it a little differently.
On the other side of the equation, in order to go up a hill, you must depress the throttle more at a given speed to climb a hill. This is because it takes more energy output to maintain a given speed at an incline. Bottom line is, the engine will need more air and fuel to make it up the hill, therefor your throttle will be open further and the computer will increase the injector pulse width to accomplish this.
  • So... you're saying that a compression-braking engine is effectively "not running" at all? Meaning that if it were suddenly shifted into neutral, it'd die instantly? – TDHofstetter Aug 15 '14 at 15:28
  • Good answer. I've never driven an automatic car though, my question about accelerator position was just theoretical assuming I don't change gear. I'm not too crazy about fuel economy, just more curious about what's going on below my feet. I just was wondering if the accelerator is literally just a squeeze on the fuel line, and the only thing that can influence how much fuel is being burnt. – Mikey Mouse Aug 15 '14 at 15:36
  • @TDHofstetter ... no. The PCM would automatically adjust for this. I don't design how it works, I just report what I know. – Pᴀᴜʟsᴛᴇʀ2 Aug 15 '14 at 18:45
  • I'd think, too, that... if the injectors got no fuel at all during engine braking, the catalytic would "starve" and "go out", requiring another restart. I think something else explains those zeroes... but not having read the document, I won't guess about their cause. – TDHofstetter Aug 15 '14 at 18:49
  • @TDHofstetter ... you also need to remember that the 1000-1500 rpm zone with TPS at 0% is a pretty slim zone. Once the engine is outside of these zones, the fuel starts flowing again. In normal driving, the engine resides in these zones very little. It is, however, inaccurate to say a transmission in neutral with engine running at idle will provide better fuel mileage than engine braking, because it just doesn't work that way. I used to think the exact same thing and was proven wrong. Fuel mapping is a beast of a task. It's very hard to get the whole picture due to how much is involved. – Pᴀᴜʟsᴛᴇʀ2 Aug 15 '14 at 19:12
Petrol consumption is the sum of many factors which in day to day driving do not concern the driver. The greatest fuel consumption figures are obtained when the highest gear possible is used, with the minimum of throttle to maintain vehicle speed or desired acceleration. Consider the new Jeep fitted with a nine speed transmission. What this works out to is at 70 MPH the engine RPM is only 1700 and means 'WOW!' figures for the MPG. Going up a hill would use more fuel as the vehicle has to carry out work to climb the hill. Coasting out of gear to save a modicum of fuel is a game for mugs to play, best not to do it. Technically, if the car is driven and coasted then the vehicle is legally out of the full control of the driver.
  • Nice answer, and don't worry about me coasting to save petrol, I'm not asking this so I can reduce a few drops of the stuff. It's pure curiosity in what goes on in the engine. – Mikey Mouse Aug 16 '14 at 20:09
  • Thank you for the kind words, I have been curious about engines since the age of four. Maybe, maybe one day...:-) – Allan Osborne Aug 17 '14 at 9:50
I agree with all the answers posted here however there is one aspect of fuel efficiency not covered. The "Engineering explained" youtube channel has a video covering fuel efficiency for conventional combustion engines. He explains that engine load vs fuel efficiency also plays a vital role, i.e you need to maintain a maximum enginer load via selecting the highest gear possible, given the driving speed, incline, vehicle load, such that the throttle is as wide open as possible to maintain the desired speed.
He explains it in much more detail so you can watch here: https://www.youtube.com/watch?v=iNspNdVkslA
Unstated in the answers is the assumption of a fuel injection engine , a safe assumption today. Fine point : the throttle controls the amount of air going to the engine. The computer then looks at various inputs and decides how much fuel to inject using the MAP ( I don't remember what that stands for). Things were different in the days of carburetors, I had a computer that precisely monitored fuel input. For an Olds V 8 ( 5.6 L) with Rochester 4 GC carburetor , essentially the same amount of fuel went in from idle ( 500 rpm)up to about 40 MPH ( 1500 rpm). Needless to say the overall MPG was not good.
  • MAP = Manifold Absolute Pressure, hence MAP sensor. – Kickstart Jan 31 at 9:12
