Civic sedan: 1997 150i
so on my home from the shop I notice at a stop that as I push the clutch down and put the gear lever into neutral, there's a soft, slight rattle before the normal sound my car makes when it's Idling, I make a stop at the garage for fuel
after I'm done getting fuel, I start up the engine, only this time the rattle is louder and I can feel it shaking on my foot that's on the clutch. I drive home slowly and after having a look I find that it's the motor that has two belts connected to it seems like the main motor/'turning thing', cos it's turning everything else on the belts and even though it doesn't look very loose, my front wheels (front wheel drive) and gear lever is shaking
can anyone tell me what that double wheel turning the belts is called and whether it's just that that's loose or could it be a more serious problem? I need my car running by saturday morning.
