I noticed recently that my Honda vibrates at low speeds/when you DON'T step hard on the throttle pedal. It doesn't do this every time and I have had my wheel balancing done and checked my engine seating. Any ideas guys?
Diesel or petrol ? – Watsche Jul 25 '14 at 11:28
@watsche, it's a petrol engine – Mahonix Honix Jul 25 '14 at 14:23
OK, then I would look at engine suspension, silent block. Then try rear wheel to front. – Watsche Jul 28 '14 at 6:33
Engine/gearbox mountings may be worn. Ignition coil(s) starting to fail. Accelerator pedal position sensor starting to wear. Fuel injector intermittant fault. There are many reasons more, so a check over at your repair shop would be recommended.
