How do I program a replacement fob for my 2003 Malibu (not remote-start equipped)?
EDIT:
I have tried to do the following: The instructions that came with the fobs said to
- Sit in the car
- Shut all doors
- Put the key in the ignition.
- Hold the door unlock button on the drivers door.
- turn the key to the on position
- turn the key to the off position
- release the unlock button on the door.
Car is supposed lock and unlock.
After that you have to hold the lock and unlock on the fob for 30 seconds.
IT DOES NOT WORK.
I have tried to sit in the car, close door, hold door lock on unlock while I enter the key, pull it out. Enter the key, pull it out, enter the key and release the door unlock button. The door is supposed to chime three times. Then I am supposed to hold the lock and unlock button on the fob for 12 seconds. The door is supposed to chime twice and the fob should be programmed.
I have tried this also and there were no chimes.
I think this product is wrong. People are telling me to take it to Chevy or a locksmith. Why do that if you say it works?
