Take the 2-minute tour ×
I would like to know what engine would last longer and with less problems? A 3 or a 4 cylinder engine? Thanks. Alik.
closed as primarily opinion-based by Mark Johnson Sep 18 '13 at 18:23
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
Please explain why you voted the question down –  AlikElzin-kilaka Jan 23 '13 at 8:56
Is miles per cylinder a major or minor factor in durability? Consider a 6 cylinder SUV versus an 8 cylinder SUV. assume the same work load for both engines. –  user3698 Sep 14 '13 at 22:03
3 Answers 3
The number of cylinders is completely irrelevant when determining the durability of an engine. Workload, used materials, building process, maintainance, etc. are far more important.
If all the factors are the same (Workload, used materials, building process, maintainance, etc), is there still a difference? For example, perhaps the 3 cylinders need to work faster to give the same output, I would expect it to ware out faster. –  AlikElzin-kilaka Jun 1 '11 at 11:38
4-cylinder, cycles are more balanced, and load is distributed across 4 instead of 3 cylinders, all other things being the same.
I've seen this question before. The debate is
Smaller engines have less moving parts to break, bigger engines have more parts to distribute load. Choose your side.
Really though, what are you going to be doing? Drag racing with spray or huge boost? Probably not gonna want a smaller engine (at least, a smaller block that is...)
It's not a question about big or small engines. I wanted to buy a small (engine) car for private genral use. I had 2 general options: 3 or 4 cylinder engine. I wanted to know which one is more durable. –  AlikElzin-kilaka Jan 23 '13 at 8:59
