I have a Jimny model year 2009. When I get up to 80 km/h, the steering wheel shakes slightly; it does the same when braking from any speed above 80 km/h down to the 80 mark, but much more violently. I've done alignment and balancing, but didn't work. Garage says it may be deformed braking discs...thoughts?
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
if the shake becomes worse when you apply the brake, then I'd agree with the garage. The rotors are wearable items and as they get older, they often develop a warp (or to be more precise according to some schools of thoughts, uneven build up of brake pad material). How many miles are on those rotors? Also depends on your driving patterns, my rotors regularly go bad in less than 2 years because the car ends up sitting unused for days and they end up rusting. The other possibility is bent rim. If rims are bad, generally no amount of balancing will stop the car from shaking. Run over any potholes/curbs lately? |
