I have a Chevy Malibu '05 4 cly 2.2l that cranks but does not start. I already put starting fluid in the intake and it started up and died real quick, which tells me there is spark but no fuel. Does anyone know what's going on?
I also changed out the run/crank relay and it started and stalled again. I will be checking fuel pressure tomorrow.
Do you have a way to check the fuel pressure? – Bob's sock puppet May 23 '14 at 2:13
No! But I'm going to try tomorrow. I also changed out the Run/Crank relay or fuel pump relay I believe is the same thing, well when I changed it it started and stalled again. I don't what it is. But I am going to check fuel pressure – Sensdeep79 May 23 '14 at 2:32
Let's not miss the obvious... are you sure there is fuel in the tank? – Zaid May 23 '14 at 3:57
First thing I would do is check the fuel pressure it should be between 50 - 60 psi. Unless you have a scan tool to command the fuel pump on then this should be done while cranking the engine. The computer commands the fuel pump on for 2 seconds when you turn on the key, and turns it off unless it sees a ignition reference pulses.
Another thing you can do is take off the fuel cap and put you ear near the opening have someone turn on the ignition while you are listening and you should hear the fuel pump come on for the 2 seconds, make sure the key is off for at least 30 seconds before turning it on. If you don't hear it come on at all then you need to make sure it's getting power and ground. Comment on this answer after you have tried that and I can give you more info.
Another thing to check is to ensure the fuses and relays for the injectors are in good order. This is definitely a fuel issue, so the OP is on the right track. – Pᴀᴜʟsᴛᴇʀ2 May 23 '14 at 20:02
my sisters malibu maxx had multiple fuel pump problems, turns out the wiring at the tank had an intermittent short
It was the fuel pump .
I believe it was detective already.. ..cause had just changed it out 2 months ago ..
So make sure you get warranty on your parts you purchase.. .
This does not provide an answer to the question. To critique or request clarification from an author, leave a comment below their post - you can always comment on your own posts, and once you have sufficient reputation you will be able to comment on any post. – Gabriel Mongeon May 25 '14 at 14:47
This appears to be the same user as the OP. If you are the OP please click the contact us link at the bottom of the page and request your two accounts be merged. – Bob's sock puppet May 26 '14 at 17:22
