I have a 1999 RAV4 with 120,000 that's vibrating at Stops when in Drive, but not when in Neutral. Would it help long term if I used Neutral when stopped? OR should I start looking for another car? I'm not a mechanic. Thanks
Does it always happen or only after the car is warm? – mikeazo Jun 9 at 12:32
It's the engine light on? – cullub Jun 10 at 17:31
This hardly sounds like a problem for which the whole vehicle needs replacement.
The symptoms could be explained by a misfiring cylinder, in which the vibrations are most obvious at idle and with the drivetrain engaged.
Common causes for misfires include ageing spark plugs/wires, absence of spark or improper fuel delivery (usually a clogged fuel injector).
A flashing check engine light would typically occur if misfires are the problem. – denver Apr 28 '14 at 13:33
I would not put it in neutral every time you stop. You risk premature wear and tear on the shifting mechanisms.
It depends on what you mean by vibration. A little (slightly inconsistent) vibration when idling is just fine and is not worth doing anything about.
you need to change your engine seat, I had same issue with my 1999 Rav4.
Welcome to the site! Great idea. but your answer could use a bit more detail as to why the 'engine seat' is the issue to be more helpful and complete. What does the engine seat do? Where is it located? Why would a bad engine seat cause this problem? Help the OP understand the problem, as well as the solution. Thanks for the contribution! – MooseLucifer Jun 9 at 13:01
