My petrol engine has developed a persistent misfire. How can I figure out which cylinder is the culprit in order to hone in on the root cause?
up vote 2 down vote accepted
It is easy to tell a misfiring engine as it will transmit unusual vibrations that vary in severity with engine load. A misfire occurs when a cylinder fails to ignite the air/fuel mixture at the right time and could happen due to a wide range of reasons, including lack of spark (a bad coil), lack of fuel delivery (clogged fuel injectors) and improper ignition timing (out-of-spec cam timing).
There are several ways to identify the cylinder(s) responsible for the misfire:
  • Use a code scanner. Most modern-day vehicles come with an engine control unit (ECU). One of the jobs of the ECU is to store engine faults, and infers the misfiring cylinder based on the readings coming from the engine knock sensors. While this approach is quick and easy, it is not always guaranteed to register the responsible cylinder.
  • Infer by elimination. The principle behind this approach is quite simple - if a firing cylinder is disabled while the engine is running the vibration "signature" will change, while if a misfiring cylinder is disabled then there will be no discernible change in engine note. This test is best done with the engine running and with appropriate PPE as it will invariably involve disconnecting coils/plug wires one-by-one. After each cylinder is tested, the coil/plug wiring should be reconnected to restore the engine note back to its baseline.
  • Observe the thermal signature. A misfiring cylinder will not generate the same level of heat as a firing cylinder. This test is best suited to engines with easy-to-access exhaust headers. With the engine cold, start it up and let it run for a few seconds before turning it off. By figuring out which parts of the exhaust header(s) are cold (an IR temperature gauge should work well here), one can hone in on the misfiring cylinder. This test doesn't work well if the engine is run for too long as the heat generated will even out across the headers.
You do not want to test cylinders by removing plug wires. In many newer vehicles, this can actually cause bigger issues with the ECU and/or ignition system. You can use other methods which involve grounding that plug wire to get the same effect without damage to the system. – ᴘᴀᴜʟsᴛᴇʀ2 Apr 13 '14 at 2:03
@Paulster2 : Can you explain the possible issues in more depth? I have used the technique I've described to troubleshoot an LS1 motor without problems, but you have more experience than me. – Zaid Apr 13 '14 at 2:28
You need to do it one of two ways. 1) Use an in-line spark plug tester, or 2) ensure the spark plug wire is grounded to listen for the difference. By pulling the spark plug wire while running, you run the risk of shorting/burning out your coil (especially in your case with the coil over setup). Your suggestions are good and thorough. Using a thermal IR temp sensor is a great way. Even if the engine is running, the temperature at the "dead" cylinder is going to be much cooler. How much, though, depends on the type of vehicle. – ᴘᴀᴜʟsᴛᴇʀ2 Apr 13 '14 at 17:45
