In a VIN (Vehicle Identification Number) code, do the first 8 digits always refer to the same make/model, or does it change from year to year?
For example, here is a VIN (5TDDKRFH5ES03F736) decoded:
  • 5TD --> Toyota (WMI [World Manufacturer Identifier])
  • DKRFH --> Highlander SUV, AWD, Engine 2GR-FE (Vehicle Attributes)
  • 5 --> check digit
  • E --> 2014 (model year)
  • S --> plant code (Princeton, Indiana)
  • 03F736 --> vehicle sequence number
If I find another VIN with the same WMI (5TD) and the same vehicle attributes (DKRFH), but the year and plant code are different, will that always still be the same make and model? (a Toyota Highlander in this example). Are there any exceptions?
I'm most interested in the North American market.
Thanks very much for your help.
Is this question specifically for Toyotas? If so, I suggest you reflect it in the question title/tags. – Zaid Apr 11 '14 at 14:07
@Zaid, no not specific to Toyotas, just using that as an example to illustrate the question. – koanima Apr 11 '14 at 14:12
The VIN format is not standard across different vehicle brands. Every manufacturer has its own way of specifying the VIN. For example, BMW uses the last 7 digits of the VIN to uniquely identify the model, year of manufacture, specs and options – Zaid Apr 11 '14 at 14:26
@Zaid Actually, only portions of the VIN are not standard and some portions are standard. You can read more about it here. For example, for North America the first three digits are the world manufacturer identifier, the ninth digit indicates the model year, and the vehicle attributes are always in positions 4-8. The actual digits within 4-8 are not standard, but set by each manufacturer. The question is if the combination from 1-8 are unique for a model, or if they could indicate another model in a different year. – koanima Apr 11 '14 at 15:08
@koanima ... you need to put that up as the answer. – Pᴀᴜʟsᴛᴇʀ2 Apr 11 '14 at 20:32
up vote 2 down vote accepted
If everything stayed the same between two years (make, model, engine, options, origin, etc), you can expect that the only thing which would change between the two years is the 10th digit (year) and the last six which indicates the serial number of the vehicle.
The breakdown of any VIN of a car from 1981 until present sold in North America is as such (from Autocheck website):
VIN decoder gif
This standard is covered under ISO 3833, but there are other competing standards throughout the world. Although, if a vehicle manufacturer wants to sell their vehicle in the United States, they will conform to ISO 3833.
For vehicles sold in North America, there should be no exceptions. In most cases the plant code will be the same amongst cars with the same vehicle attributes, because it becomes a lot more expensive for an auto manufacturer to have two plants rolling out the same cars. The logistics involved creates a greater expense for two plants. (It's a lot more economical to add more workers and/or assembly lines at the same plant than it is to run two identical plants.) Some manufacturers do assemble the same vehicles at different plants, such as VW, which does this with the Jetta (Germany and Mexico). The difference here would be, there would be a change in the first letter of the VIN as well as the plant being different.
Is WMI (world manufacturer id) + VDS (vehicle descriptor section) enough to identify the make & model, or is it necessary to include the model year also?
If you know a certain vehicle is a Toyota and you take the last eight to the dealership and ask them questions, they should be able to identify it with this information alone (they will cross reference the last eight with their database to see the whole picture of the vehicle in question). If you are trying to do it by internet search or on your own, you'll need to have the complete VIN in order to see what the vehicle make/model/year/etc is.
