I'm trying to locate a wiring harness for my new stereo that I want to install into my 2000 Chevy Cavalier, but I'm having a difficult time find one.
Does anyone know of a after market harness that would fit my car?
Best Buy will have one. Go to their stereo installation shop, which is usually accessed around the side of the building. They will have the harness adapter which will plug directly from your new stereo to the existing wire harness without the need for modification, so you can reinstall your old stereo if you ever sell the car. They will also have professional facial plates for a clean install. Both of these will make installation very easy.
  • My local Best Buy stores only sell the complete kit. I only need the harness. Apr 12, 2014 at 18:32
  • You can also purchase them online, by themselves, from Best Buy. Apr 12, 2014 at 18:51
  • Do you happen to know of a guide for matching harness to model? Apr 12, 2014 at 19:03
  • You just need to know the vehicle manufacture. The harness is soldered (for best results) onto the radio harness. The wiring colors have been standardized from the radio manufacturer. Even if it isn't, it should all be labeled. Apr 12, 2014 at 19:05
Go to Crutchfield.com under Car Audio, Build your System, click find what fits your car. Enter your car info and then click on the Parts & Tools to install a receiver, then Factory System Adapters. There will be a list of what fits your car.
Note you may need more than an adapter that simply connects the wires to the wires. In 2000 GM started running the door chime, and other warning sounds (seatbelt, low fuel, low oil pressure etc) through the radio. If you are installing an aftermarket radio in one these vehicles you will need an integration adapter to keep the chimes and safety warnings.
Below is an example of what you need. You didn't provide enough information in your question for me to tell you the exact model so you will need to go to the site and look up the correct one for your vehicle.
CRUX SOCGM-17 Factory Integration Adapter
Installing an aftermarket receiver in many late model GM vehicles means losing the chime that warns the door is open, along with audible safety warnings. The Crux SOCGM-17 GM Class II Data Bus Interface lets you replace the factory receiver in these vehicles and keep the door chime and all audible safety warnings.
Connect the SOCGM-17 to the wiring harness on your new car stereo, mount the module in a convenient location, and plug it into the existing factory plug. Get the great sound you want, and keep all important safety features intact. This adapter does not work with GM's Premium Bose® systems or Onstar®, and it won't allow you to keep your factory steering wheel audio controls. It will work with the standard Bose system. Warranty: 1 year.
