I have a Yamaha XJ6 from 2012 and I would like to change the exhaust. But I have a choice.
Do I change only the muffler or the whole "line"?
Other than cost what are the pros and cons of changing the muffler vs. the whole line?
You have to look at two things: money and goal. These two things come up all the time when deciding what to do with a vehicle. Figure out your goal, then how much money you want to spend. It will make this a whole lot easier to make decisions. – Pᴀᴜʟsᴛᴇʀ2 Apr 8 '14 at 15:31
Thank you Paulster, for the goal the idea is to make more noise in order to warn car drivers that I am here. The Butget in tiself would be between 500 and 800 euros. – HappyDump Apr 8 '14 at 15:39
Take a look at this forum ... they have a whole list of aftermarket exhausts for the XJ6. – Pᴀᴜʟsᴛᴇʀ2 Apr 8 '14 at 15:47
Thank you, but what are the pros and cons of both solutions? – HappyDump Apr 8 '14 at 15:48
A full system may require you to have your carbs recalibrated slightly to take advantage of the higher exhaust flow rate (someone tell me if I'm smoking something). If you're just after noise, just get a new muffler. Full systems are really only for when you want a little extra power. – Juann Strauss Apr 8 '14 at 16:05
up vote 4 down vote accepted
The 2012 XJ6 is fuel injected, so an aftermarket exhaust (Arrows, Leo Vince, Scorpion, Two Brothers, Akrapovic etc) would be easily procured. You may even get good deals on used slip-on exhausts, and you could then re-pack the glass wool (other as applicable) if required.
In order to keep the cost down, you could opt for a slip-on exhaust (muffler) instead of a full-system ("whole line"). In either case, some performance benefits and varying levels of exhaust note changes will be obtained. In either case, significant weight reduction is possible. In my case, the stock exhaust was 11 kilos, while my aftermarket full system was under 3.5 kilos.
The stock maps that come tuned for the stock exhaust may not allow you to extract all that the aftermarket exhaust could give. For this, a piggy-back module like the Dynojet Power Commander, or Bazzaz units that allow you to load a different (read richer) map will help with the gain in performance you would desire. In addition, such units allow you to get rid of flat spots in the stock map, to keep the power delivery linear over the rev-range.
There are other options like Tuneboy and Flashtune that remap the stock ECU instead of requiring a piggy-back unit. However, these may void your warranty.
Please be aware that certain cities have regulations that govern the permitted sound level for exhausts. Most exhausts come with baffles that reduce the sound output to an extent. Please check the regulations in your area of use before you pull the trigger.
happy riding!
Wow, that was an awesome answer, thank you very much! Exactly the kind of informations I was looking for. – HappyDump May 15 '14 at 8:16
Happy to be useful! Feel free to reach out anytime. – Shrinivas May 19 '14 at 9:29
Will do. Thanks again. – HappyDump May 19 '14 at 13:35
@Shrinivas, you forgot yoshi.. ;) and yes, a a stock map will not allow to unlock its full potential. But still, the ecu varies the timing and AFR ratio to some extend to cope up with the sudden change/ free flowing of the exhaust gas through the outlet manifold. And btw, which bike do you ride?? Curiosity.. – You_Shall_Not_Pass Sep 26 '14 at 9:12
@You_Shall_Not_Pass, I ride a 2012 Ninja 650 primarily. Running a full system Leo Vince Underbody Evo II exhaust, Power commander 5 and custom maps. You? – Shrinivas Dec 3 '14 at 9:29
